*Robert
Message 11 of 27 (355 Views)
Re: Count Down
06-01-2010 07:44 AM in reply to: *wfb
I'm out of the loop here. What are you refering too?
"wfb" wrote in message
news:6400587@discussion.autodesk.com...
Three (3) days and counting.
Bill
*Srayos Endbringer
Message 12 of 27 (355 Views)
Re: Count Down
06-01-2010 08:06 AM in reply to: *wfb
Autodesk, in their infinite wisdom, is getting rid of the newsgroups and
moving them to a web based forum only.
EB
Win7 Pro 64-bit
Civil 3D 2011 64-bit
6GB RAM
> Bill
*Domagoj X
Message 13 of 27 (355 Views)
Re: Count Down
06-01-2010 08:17 AM in reply to: *wfb
> Bill
Lets make it more epic
http://www.youtube.com/watch?v=u8zla30TCzw&feature=youtube_gdata
*Robert
Message 14 of 27 (355 Views)
Re: Count Down
06-01-2010 08:35 AM in reply to: *wfb
So then using Outlook will be no more?
"Srayos Endbringer" wrote in message
news:6400659@discussion.autodesk.com...
EB
Win7 Pro 64-bit
6GB RAM
> Bill
Valued Contributor
MSBryan
Message 15 of 27 (355 Views)
Re: Count Down
06-01-2010 09:51 AM in reply to: *wfb
> {quote:title=dei-feif wrote:}{quote}
> > {quote:title=Guest wrote:}{quote}
> > I guess this is the last week I'll really be reading these. This just
> > means a higher cost to Autodesk because now I'll be using the support
> > requests for everything instead of coming here and reading if someone
> > else had the problem first.
> Unfortunately, that might be better overall.
> When people solve problems by coming here instead of reporting them to Autodesk, it gives Autodesk the impression that it isn't really a problem. They only seem to fix things that get a lot of complaints. So maybe filing every single problem with Autodesk support will be better - we might get more of the problems fixed, instead of needing to work around them year after year and release after release.
> -- Sinc
> http://www.ejsurveying.com
> http://www.quuxsoft.com
Sinc,
I think you have a very valid point, but I also think that some problems are solved via the reseller or implementation teams and so those issues never make it to the discussion boards.
At a previous employer we had problems with not being able to check drawings in to the vault. I personally thought the issue was possibly a switching or latency issue with our network (that's probably not the best description). A situation caused by the way our network was set up vs the way vault was intended to be set up. We escalated the issue up the ladder and had an Autodesk developer log in and look at our setup. I personally wasn't available during that session (can't guaranty I would have been helpful). The tweeks that were made temprorarily solved our issues, but the problems eventually came back. I switched jobs since that occured and know that they now are moving everything to data shortcuts as the issue was never fully resolved.
The point I'm trying to make is that during that time, I scoured the web and discussion groups for similar issues as to what we were running into and never found any significant conversation or data to help us resolve our problems. I have experience with implementing massive site installations of Oracle and know that a lot of the time issues are resolved on one off basis or sometimes during testing, only to pop up randomly weeks or months after implementation and no one, other than the initial team who resolved it, ever knew it was an issue to begin with.
MB
*Civil_EITguy
Message 16 of 27 (355 Views)
Re: Count Down
06-01-2010 11:03 AM in reply to: *wfb
Which means more programmers and engineers to fix the problems and who
pays for that????
Not Autodesk.
*John Mayo, PE
Message 17 of 27 (355 Views)
Re: Count Down
06-01-2010 01:17 PM in reply to: *wfb
"The tic tock of the clock is painful..."
:smileysurprised:
John Mayo, PE
Win 7 64, C3D & RD 2010
Core i7 920, 6 GB DDR3
Quadro FX 1700
*Srayos Endbringer
Message 18 of 27 (356 Views)
Re: Count Down
06-02-2010 07:18 AM in reply to: *wfb
Yes, no more using Outlook or Thunderbird to read the newsgroups.
Autodesk is forcing everyone to use the web based system.
EB
Win7 Pro 64-bit
6GB RAM
> EB
> Win7 Pro 64-bit
> 6GB RAM
>> Bill
*Matt.Anderson
Message 19 of 27 (356 Views)
Re: Count Down
06-02-2010 07:34 AM in reply to: *wfb
Outlook will work fine as long as you read via RSS...
Matthew Anderson, PE
> EB
> Win7 Pro 64-bit
> 6GB RAM
>> EB
>> Win7 Pro 64-bit
>> 6GB RAM
>>> Bill
Sinc
Message 20 of 27 (356 Views)
Re: Count Down
06-02-2010 07:48 AM in reply to: *wfb
I think what will be most disappointing is if, after the upgrade, we still have basically the same pathetically slow software.
Sometimes it works OK, and is only three or four times slower than most other forums. But other times, it's terrible. This morning is a great example. I click on a thread, and it takes several minutes to load. So I've been clicking on a thread, then switching to another browser tab and reading three or four threads in another forum, then switch back to this tab to read the thread that FINALLY loaded.
Some days it's even worse, and these forums are completely inaccessible for hours. I see an awful lot of "WebSeal" error pages.
-- Sinc
Sinc
