i have been working on a DWG (c3d 2012) most of the day, and sure enough, after my last edit in Model space, c3d crashed.
i can remain in model space, but once I try on open the only layout tab, c3d hangs and crashes. i was able to create a new layout in the command line and rebuild my layout, but i still cannot open the original tab without a crash. i ran AUDIT and found 2 errors, but if i allow c3d to fix or delete them, c3d crashes. also, if i run PURGE, c3d crashes.
any idea how i can determine what is at fault or a method to maybe even isolate the problem? maybe a trick?
tia
