When you do an uninstall, you should be sure to also clean your registry of the Autodesk entries. Go to Autodesk.com, find search and search for TS45252. That tech doc will tell you how to clean the registry. If you uninstall, delete the program folders that are left over, and clean the registry, the re-install should be successful.
Best regards,
Tim Corey
Delta Engineering Systems
Redding, CA
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
