Civil 3D Forum
Corrupt Surface and C3D crashes
5 REPLIES 5
todor.latev
437 Views, 5 Replies
Working on a fairly complex C3D surface and experiencing frequent app crashes - every 10-15 mins
Decided to run a purge/audit, but it results in my surface loosing all it's history - feature lines, boundaries, breaklines, points etc
I end up with a static surface which is not acceptable
Here's the output from the audit command:
Pass 1 5700 objects audited
Tin Surface FG has become corrupted
Tin Surface FG rebuilt from surface points - may not match original
Pass 1 7100 objects audited
Auditing Entities Pass 2
So - can't fix the dwg, cause I loose all my surface Definition /in prospector/ and I cant work with this file because of the frequent crashes/freezes
/every time I try to undo, 3d orbit etc/
Any advice?
C3D 2015 x64, SP1, Win7 x64, 16Gb RAM
5 REPLIES 5
Jay_B
in reply to: todor.latev
What version & Service Pack?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
todor.latev
in reply to: Jay_B
C3D 2015, SP1
Jay_B
"Decided to run a purge/audit, but it results in my surface loosing all it's history - feature lines, boundaries, breaklines, points etc"
Do you know if the Template used to create this dwg was originally based on the OOTB 2014 or 2015 Acad.dwt ?
C3D 2018.1
C3D 2016 SP4
todor.latev
in reply to: Jay_B
not sure - it was either a custom /project specific/ template or the standard C3D template that ships with C3D 2015
Jay_B
The reason I asked about the dwt used is there are some known issues when using the Acad.dwt as a starting point in the 2014 & 2015 releases.
C3D 2018.1
C3D 2016 SP4
Rail Community
