I tried to open a dwg from an old server and got the "Drawing file is invalid". I read many discussions on this. I've tried to recover and open in TrueView with no success. A couple of posts said to drag a dwg into Notepad and if the first line began with AC and some numbers it's a good file. I did this with a nonvalid dwg and oriental characters appeared. A good dwg had the AC... and normal looking "garbage". Has anyone come across the oriental character situation with invalid files?
I'll give it a whirl if I can find a microstation user to try it. I really need some heavy hitters who can look at a dwg from different angles and determine what happened to it. Many files are this way.
FWIW, Microstation V8i returns the error File Path\Cad.dwg is not in a recognized file format.
