Civil 3D Forum
Corrupt .dst?
8 REPLIES 8
Message 1 of 9
sjg
881 Views, 8 Replies
Corrupt .dst?
Is it possible to have a corrupt .dst file, I have a sheet set with over 300 sheets created with Mapbooks and everytime I try to open just the sheet set in the SSM it take forever to open and when it does open can't do anything with it continuously acts like it is opening. Or could it be a corrupt file within the Sheet Set. Basically xref'd 2 drawings in to create the drawing. Anyone else have issues before.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
8 REPLIES 8
Message 2 of 9
rkmcswain
in reply to: sjg
What is the size of the DST file?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
sjg
in reply to: rkmcswain
314 KB
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 4 of 9
rkmcswain
in reply to: sjg
Ok, probably not the same problem I have had a couple of times.
Mine would get very slow (with ±80 sheets) and I would notice the DST file size was like 8MB.
I was able to use some tools to examine the guts of the file and found tons of garbage deposited there by AutoCAD.
Resorted to a backup each time.
Message 5 of 9
Joe-Bouza
in reply to: sjg
There are known performance issues with SSM, particularly with large ones. By default SSM reads out to your server to determine what fields need to be updated.
The system variable I have found helpful are: SSMSHEETSTATUS & SSMPOLLTIME
SSMSHEETSTATUS=2 TELLS SSM to refresh as per SSMPOLLTIME= <20 TO 600 sec>, this can result in long refresh times for larger sets.
If SSMSHEETSTATUS=1, fields update on open.
Play with the numbers see what works for you.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 6 of 9
sjg
in reply to: Joe-Bouza
I just went ahead and changed SSMSHEETSTATUS = 1, that seemed to do the trick. Didn't have a problem with it before till yesterday. Thanks I appreciate it, was really getting frustrated.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
16 GB RAM
Nvidia Quadro 600
Message 7 of 9
Joe-Bouza
in reply to: sjg
HTH.
I know what you mean. It can be finicky
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 8 of 9
auzzie2776
in reply to: sjg
good tip of the SSM joe. How ya been mate ?
Message 9 of 9
Joe-Bouza
in reply to: auzzie2776
Hey, long time Smiley Very Happy good to hear from you. We are well, and you?
Are you far from Del Ray?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
