EGPT stands for Eagle Point, and COULD be A reason you're having issues...
Not sure why you can't get to my blog, but this is the entry:
You have a problem drawing. It's slow to respond to commands, it's bogging
down, and the visual content doesn't justify the file size. It crashes for
no apparent reason, you can't nail down the problem, and it seems to be
getting worse.
Computer hardware problems, power surges, user mistakes, or software
problems can cause errors that prevent you from editing or plotting the
drawing. By saving and AUDITing your work regularly, you can ensure a
minimum of lost data if your system fails. It's interesting to note, if you
AUDIT a drawing, and the command hangs for no apparent reason, you may have
the following issue:
RegApps
Some major programs on the market (not an Autodesk, Bently, or Carlson
product) have a tendency to save registered applications with an invalid
name, such as "##*a%")?s*" in an AutoCAD drawing file (similar to an
anonymous block). Anytime this drawing is used, even as an xref, new
"##*a%")?s*" RegApp entries will be added to the drawing referencing it, as
AutoCAD doesn't recognize that "##*a%")?s*" is already registered in the
current drawing; a "virus" is born. Invalid RegApp entries will balloon a
drawing over time, Audit will report no errors, but at some point, the
drawing will no longer open. You can check if the "bloating" is indeed
caused by this "virus" by doing the following test:
Issue the following command at the AutoCAD command prompt:
(tblnext "appid" 5)(while (print (tblnext "appid")))
If this action produces a similar listing to the one below (often scrolling
infinitely), you need to clean the infected drawing ("EP" is a reference to
Eagle Point):
((0 . "APPID") (2 . "EP##*a%") (70 . 0))
If you enter -purge at the Command prompt, -PURGE displays the following
prompt on the command line:
Enter type of unused objects to purge:
[Blocks/Dimstyles/LAyers/LTypes/Plotstyles/SHapes
/textSTyles/Mlinestyles/Tablestyles/Regapps/All]:
Enter "R" to purge unused applications. -PURGE removes only one level of
reference. Repeat -PURGE until there are no unreferenced named objects. As
an alternative, download the following routine (will clean an entire
directory and any attached x'refs):
http://tinyurl.com/bbmkz
Thanks to James Maeding, Shaan Hurley and the Autodesk Developer Network for
making this tool available! The tool can be used to purge unwanted Layer
Filters and unnecessary REG APP IDs in DWG files. This tool actually purges
any APP ID that is not needed, just like the -PURGE command does in AutoCAD.
This tool works for AutoCAD 2000 up to AutoCAD 2005. I've tested it for
clients in AutoCAD 2006, and while it's slightly fussy, it does work.
Browse to IntelCAD for more information on
RegApps:http://www.intelcad.com/pages/recover/
sm
Scott McEachron
DC CADD, Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
wrote in message news:5119661@discussion.autodesk.com...
hi scott,
for some reason i cannot get to your blogspot.
as for "something similar" i get:
((0 . "APPID") (2 . "ADE_PROJECTION") (70 . 0))
((0 . "APPID") (2 . "DCO15") (70 . 0))
((0 . "APPID") (2 . "ADE") (70 . 0))
((0 . "APPID") (2 . "RAK") (70 . 0))
((0 . "APPID") (2 . "AcAecLayerStandard") (70 . 0))
((0 . "APPID") (2 . "ACAD_PSEXT") (70 . 0))
((0 . "APPID") (2 . "ACAD_EXEMPT_FROM_CAD_STANDARDS") (70 . 0))
((0 . "APPID") (2 . "AcMapDMDisplayStyleRegapp") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIMEXT_LENGTH") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIMEXT_ENABLED") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIMJOGGED_JOGANGLE_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIMARC_LENGTH_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_EPOD") (70 . 0))
((0 . "APPID") (2 . "ACET-TEXTMASK") (70 . 0))
((0 . "APPID") (2 . "ALIGNMENT_DB_APP") (70 . 0))
((0 . "APPID") (2 . "AcDbAttr") (70 . 0))
((0 . "APPID") (2 . "ARCV2CAD") (70 . 0))
((0 . "APPID") (2 . "CIVIL_DRAFT") (70 . 0))
((0 . "APPID") (2 . "CIVIL_LINE_TABLE") (70 . 0))
((0 . "APPID") (2 . "CIVIL_CURVE_TABLE") (70 . 0))
((0 . "APPID") (2 . "CIVIL_SPIRAL_TABLE") (70 . 0))
((0 . "APPID") (2 . "SVPLINE") (70 . 0))
((0 . "APPID") (2 . "AEC_DWGVARSSETUP_DATA") (70 . 0))
((0 . "APPID") (2 . "ADCADD_ZZ") (70 . 0))
((0 . "APPID") (2 . "SDSK_PMN") (70 . 0))
((0 . "APPID") (2 . "SDSK_POINT") (70 . 0))
((0 . "APPID") (2 . "SDI_XSECTIONS") (70 . 0))
((0 . "APPID") (2 . "DCA_FIGURE_XENT") (70 . 0))
((0 . "APPID") (2 . "AEC_DISPREPCONFIG_DATA") (70 . 0))
((0 . "APPID") (2 . "AEC_DISPREPSET_DATA") (70 . 0))
((0 . "APPID") (2 . "EGPT_COLORFAST_PAPER") (70 . 0))
((0 . "APPID") (2 . "ABNSLEADERTOOLS") (70 . 0))
((0 . "APPID") (2 . "PE_URL") (70 . 0))
((0 . "APPID") (2 . "SDI_SETUP") (70 . 0))
((0 . "APPID") (2 . "JASPER") (70 . 0))
((0 . "APPID") (2 . "EDS_ALIGNMENT_DATA") (70 . 0))
((0 . "APPID") (2 . "M2M9930721E123627240-2147483605") (70 . 0))
((0 . "APPID") (2 . "3195211092EDS19930721E142536280") (70 . 0))
((0 . "APPID") (2 . "EGPT_NODE") (70 . 0))
((0 . "APPID") (2 . "EGPT_END") (70 . 0))
((0 . "APPID") (2 . "EGPT_NODE_LEADER") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_POC_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_HEAD_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_VALVE_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_FITTING_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_EMITTER_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_EQUIPMENT_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_PUMP_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_CONTROL_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_BACKFLOW_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_WATER_METER_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_LC_PLANT_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_EVAL_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_LD_PLANT_SYMBOL") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_PIPE_LEG") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_WIRE_LEG") (70 . 0))
((0 . "APPID") (2 . "EGPT_LCAD_AI_DRIP_LEG") (70 . 0))
((0 . "APPID") (2 . "AECGUIBASE") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIMTEXT_FILL") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIM_LINETYPE") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIM_EXT1_LINETYPE") (70 . 0))
((0 . "APPID") (2 . "ACAD_DSTYLE_DIM_EXT2_LINETYPE") (70 . 0))
((0 . "APPID") (2 . "EPNODE") (70 . 0))
((0 . "APPID") (2 . "MStation") (70 . 0))
since i cannot get to your blogspot i have no clue as to what it all
means...
