We are working on same project in different files in different C3d 2013. Now as our design is finished we are looking to merge various corridors in to one file. Tried to copy and paste all the corridors along with Targets in one file it will copy all the elements (alignments,assemblies). but when we rebuild the corridors every thing semms to be displaced. Appears that we need to map the targets again in the new merged file.
is there any quick fix of this problem or pl advise if other method is there to merge the corrridors.
WFberry , Initially tried with Corridor Xml import but seems no help as C3D 2013 imports the associated alignments only not the corridor.
Corridors are one thing in Civil3d that can't be transferred between drawings. Usually I just XRef the various corridor drawings into one file, data reference the design surfaces and go from there.
Are you trying to merge these corridors in order to calculate quantities or to create finished sheet drawings?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Thank you Steve.
As the project is not big enough to separate different elements in different C3D file our Client need a single design file of the project.
