I am probably just missing something simple but I have created an assembly with the basicsideslopecutditch subassembly and I created a corridor using my alignment and profile information, in plan I can see that the corridor lines are showing daylights but when I look at the section viewer I cannot see my existing ground surface or my daylight subassembly. I can see the dots were the ditch or fill slope should be but the lines don't show up. Or the existing ground line.
I also get the error "no sideslope intersect found" I searched that error and some say its because the surface doesn't go out far enough, which is not true in this case, I have lots of surface and I can see the daylight lines in the plan view of the corridor model.
Any help would be great.
thanks
Solved by Mpendlebury. Go to Solution.
I seem to get random sections that won't display but if none of your sections are displaying.
For display check the following
under sufrace styles - Display - Sections makes sure that its on for the EGL
In your corridor section viewer check
If its not a display issue, double check your target surface for the corridor make sure the daylight isnt some fearture line left over from before. Audit purge, try changing the target see if its behaving how it should.
Hope it helps
Thanks all suggestions let to a solution to the problem... Thanks. Great to have this resourse.
We had a similar problem that ended up being a layer issue. The surface object was on one layer (that if I remember correctly was frozen or off) and the layer for the contour display in the surface style was fine which is what we kept checking. Once we got the correct layer on everything was ok in the section viewer.
