Regrettably Civil 3D does not make this problem easy to solve. There are a couple of ways to solve it when there are vertical curves involved. One is to create profiles for the edges of pavement and use them as vertical targets for the lane subassemblies. The other is to use superelevation parameters. I believe the best solution is to use the superelevation parameters since it is more dynamic.
You'll find some tutorials on how to use it in the help system. If your cross slopes are not dictated by design speed you'll NOT want to use the wizard, as it will be more work to adjust the results afterward. Instead create the transitions manually in the editor.
Be aware that you will need to use lane subassemblies that support superelevation.
I concurr with Neil that the superelevation is the best way. That's exactly what it's meant for and it's quite easy. I like to use the superelevation view instead of the table, but thaty's me. I like the visual aspect of it.
Hi Matt,
While the superelevation tools get the job done I feel it's overkill for site grading scenarios. I think it is safe to say that most site designers are not versed in the principles of superelevation so it is not a readily useful tool for their needs.
I'd like to see a more basic method for controling cross slope. Perhaps a dialogue where the user inputs station and cross slope in a table with an optional graphical station picker.
While the SE dialogue does provide this functionality it is cumbersome and not all that intuitive.
