Civil 3D Forum
Corridor targets
2 REPLIES 2
joseph2.hamer
1316 Views, 2 Replies
Corridor targets
I'm currently doing the vertical design for a roundabout in C3D 2013 and as part of this i'm targeting the circulatory carriageway crownline which is a looped alignment. My corridor is built off the crownlins and tie in tangential to the circulatory carriageway crownline. However when i when i have set my target for the carriageway they are targeting the opposite side of the circulatory carriageway crownline. See attached image. I havent had any issues with this before on other roundabouts. (see attached). There is only one alignment to target so i dont need to set carridor to target nearest or furthest alignment. Has anyone had similar issues?
2 REPLIES 2
sboon
in reply to: joseph2.hamer
How is the central alignment defined?  Is it a fixed three point curve, a center point and radius definition or something else?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
joseph2.hamer
in reply to: sboon
Ive just bought in the circle wich showed the crownline and then traced over it as polyline (2arcs) and then created alignment from objects, this is the same method i have used for previous roundabouts
Rail Community
