Hi Chakri,
Not just surface labels, but contour labels, too. 🙂
Jon
"Chakri Gavini" wrote in message
news:4827366@discussion.autodesk.com...
Corridor surfaces are dynamic (as long as they are not exported) in R2005
also. Also "corridor surface sections" should be dynamic too!
In R2006, you can label link/point/shape codes on corridor (assembly)
sections with in a section view.
Thanks for the input on "applying surface labels" on to corridor (dynamic)
surfaces. More use cases you mention, will help us more in delivering even
better product.
Thanks again
Chakri Gavini
Product Designer
Autodesk Inc
"Jon Rizzo" wrote in message
news:4827311@discussion.autodesk.com...
> This labling limitation still exists in 2006. I'm not sure about cross
> sections because I haven't tried it, but it's probably the same problem.
> It
> IS possible to calculate volumes based on a corridor surface. That's nice
> at least...
> BTW: The corridor surface IS dynamic until you have to export it for the
> reasons that I mentioned in my previous post.
> wrote in message news:4826698@discussion.autodesk.com...
>> I have the same problem!. I see in civil3d2005 that corridor surfaces
> isn't dynamic. In section view this kind of element don't update
> automaticaly!!..........Anybody know if in civil3d2006 this persits???
>> Thanks
>> Joao
