Civil 3D Forum
Corridor Surfaces
3 REPLIES 3
210 Views, 3 Replies
Corridor Surfaces
Hello all, How do you go about incorporation additional information into a corridor surface, or the corridor surface into another surface? My situation is a residential area and I have a corridor that runs to the back of walk. How do I then expand this out to the lots themselves? Thanks -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM
3 REPLIES 3
apweng
From the corridors menu you can export the corridor surface as a regular surface. Now you can add whatever data you want.
Andrew
Thanks, Does the surface loose it's connection with the corridor? -- Brian Hailey LDT2005 C3D2005 XP Pro - SP 2 P4 2.8GHz 1.00 GB of RAM "apweng" wrote in message news:14509278.1101339169039.JavaMail.jive@jiveforum2.autodesk.com... > From the corridors menu you can export the corridor surface as a regular > surface. Now you can add whatever data you want. > > Andrew
Scott Wolfe
Yes, most anoying.
Rail Community
