AutoCAD Civil 3D General Discussion
New Member
LOUISEBEST19
Message 1 of 4 (1,085 Views)
Accepted Solution
Corridor Surfaces & Superelevation
1085 Views, 3 Replies
02-26-2013 03:21 AM
I have an alignement to which I have applied superelevation.
The superevation has been applied and the alignment has been annotation and it shows the change from camber to superelevation on  the curves.
However when I create a surface of my corridor it does not show the superelevation, the surface is showing a cambered alignment throughout.
Any suggestions?
I have created a new alignment, a new corridor and surface and still the same.
Have you chosen a lane subassembly that supports superelevation and set "Use superelevation" parameters within that subassembly?
Please see attached
*Expert Elite*
Jay_B
Message 2 of 4 (1,067 Views)
Re: Corridor Surfaces & Superelevation
02-26-2013 04:42 AM in reply to: LOUISEBEST19
Please see attached
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Active Contributor
w_davis
Message 3 of 4 (1,053 Views)
02-26-2013 07:21 AM in reply to: Jay_B
When creating the assembly I usually use crowned road and you can choose the slope (+ OR - 2% for me usually) or when choosing a lane you can also determine the slope.  So build the Assembly on one side and then copy it over. then when I create my surface using top links it usually shows the crowned road top along my alignment.
New Member
LOUISEBEST19
Message 4 of 4 (1,017 Views)
02-28-2013 03:55 AM in reply to: Jay_B
Thats for this!
I had chosed the UKIE Carriageway, which I presumed would be ok.
When I check the settings box there was no option to change the working of the superelevation. There was one box that said superelevation with a number 6 after it. I presume this is a code.
I started again with a new assembly.
I used a standard DMRB template and adjusted it to suit my requirements, the carriageways on all these templates had the superelevation option which you showed.
Post to the Community
New Post
Need installation help?
