I have an alignement to which I have applied superelevation.
The superevation has been applied and the alignment has been annotation and it shows the change from camber to superelevation on the curves.
However when I create a surface of my corridor it does not show the superelevation, the surface is showing a cambered alignment throughout.
Any suggestions?
I have created a new alignment, a new corridor and surface and still the same.
Solved by Jay_B. Go to Solution.
Have you chosen a lane subassembly that supports superelevation and set "Use superelevation" parameters within that subassembly?
Please see attached
When creating the assembly I usually use crowned road and you can choose the slope (+ OR - 2% for me usually) or when choosing a lane you can also determine the slope. So build the Assembly on one side and then copy it over. then when I create my surface using top links it usually shows the crowned road top along my alignment.
Thats for this!
I had chosed the UKIE Carriageway, which I presumed would be ok.
When I check the settings box there was no option to change the working of the superelevation. There was one box that said superelevation with a number 6 after it. I presume this is a code.
I started again with a new assembly.
I used a standard DMRB template and adjusted it to suit my requirements, the carriageways on all these templates had the superelevation option which you showed.
