Civil 3D Forum
Corridor surface won't form correctly
2 REPLIES 2
Nik-D
527 Views, 2 Replies
Hi all,
I have been banging my head against a wall for a while now trying to get this corridor surface to form properly. It wont seem to triangulate properly from where I have copied the intersection into the East-West corridor. Any suggestions would be appreciated.
Cheers
NIk
2 REPLIES 2
BrianHailey
in reply to: Nik-D
In the following image, I've issolated one baseline.
The issue you are having is you are adding featurelines from this baseline and they will connect from one side to the next. If you need to add featurelines, you'll need to break this up into two baselines (same for the other cross street).
For your corridor, you can get away with just adding the top links and no featurelines. If you corridor has an irregular cross section at some point (such as a widening or narrowing) then you'll need to add in the featurelines.
HERE is your drawing the way I would do it.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Nik-D
in reply to: Nik-D
Cheers I see whay you have done. I did not realise that by putting the TOP link it puts in the top links of all the subassembly parts. I thought yu had to individually specify which bits you wanted. This has made my life a lot easier.
Cheers
Nik
Rail Community
