Civil 3D Forum
Corridor surface will not fill entire corridor
12 REPLIES 12
Message 1 of 13
nhuckla
1591 Views, 12 Replies
It seems as though the surface is being cut off.  How can I fix this from happening?  See attached picture.
12 REPLIES 12
Message 2 of 13
mathewkol
in reply to: nhuckla
It might be one of your subassemblies.  Attach an image that shows your assembly and describe which subassmeblies you've used.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 13
nhuckla
in reply to: mathewkol
starting from the left of the assembly:
1 General Daylight
2 Basic Lane
3 Basic Lane
4 Basic Lane
5 Basic Lane
6 I tried linksloptosurface here but did not get the result I was looking for.  Still trying to find one.
Message 4 of 13
mathewkol
How did you create your surface boundary?  You should have used "Corridor extents" or the feature lines dayight on one side and the road edge on the other..
Matt Kolberg
Message 5 of 13
nhuckla
The picture attached is the boundary that I am using.  How do you use Corridor Extents?  Yes one side is daylight and the other is a lane subassm.
Message 6 of 13
mathewkol
That image doesn't tell me anything.  how did you create that boundary?
Matt Kolberg
Message 7 of 13
nhuckla
I created the boundary by setting it to daylight the top links.  Is this what you mean?
Message 8 of 13
mathewkol
Yeah, that's what I mean. I'm not sure how you could have specified daylight as a boundary since you only have daylight on one side.
Remove that boundary and use the interactive option then follow your outermost feature lines until the boundary is closed.
Matt Kolberg
Message 9 of 13
nhuckla
Ok.  Thank you.
Message 10 of 13
mathewkol
If you have 2013 you could select corridor extents as a boundary. If 2012, that option comes if you have more than one baseline...even if that other baseline is blank (hint).
Matt Kolberg
Message 11 of 13
nhuckla
Yeah.  I am using 2012.  What do you mean baseline?  The interactive function will take a long time, because of all the points every 5 feet for the entire corridor.
Message 12 of 13
mathewkol
Interactive really shouldn't take long at all if you don't have that many regions.
Here is an article I wrote which explains how you can use the extents.
http://www.civil4d.com/2009/09/magic-corridor-boundary/
Matt Kolberg
Message 13 of 13
nhuckla
Works great.  Thank you.
Rail Community
