It seems as though the surface is being cut off. How can I fix this from happening? See attached picture.
Solved by mathewkol. Go to Solution.
It might be one of your subassemblies. Attach an image that shows your assembly and describe which subassmeblies you've used.
starting from the left of the assembly:
1 General Daylight
2 Basic Lane
3 Basic Lane
4 Basic Lane
5 Basic Lane
6 I tried linksloptosurface here but did not get the result I was looking for. Still trying to find one.
How did you create your surface boundary? You should have used "Corridor extents" or the feature lines dayight on one side and the road edge on the other..
The picture attached is the boundary that I am using. How do you use Corridor Extents? Yes one side is daylight and the other is a lane subassm.
That image doesn't tell me anything. how did you create that boundary?
Yeah. I am using 2012. What do you mean baseline? The interactive function will take a long time, because of all the points every 5 feet for the entire corridor.
