After you go thru and setup all of the links and feature lines that you want to use to create a corridor surface, is there any way to save that particular setup to be used on other corridors? That way you would not have to select all of them again and again, every time that you wanted to create, say a datum surface.
Hi Bryan,
I have never found a way to preserve the settings for corridor surface definition.
Brent
