I've created a corridor of a ditch with a 0.5% logitudinal grade 1m wide, 1.5:1 slope and I have an OG surface. Eventually what I want is a volume of cut between my OG surface and the ditch.
My alignment has 4 subasseblies the two slopes going up 1.5:1 on the left and right are Link Slope to Surface, while the bottom of the ditch are Link Width with Slope (0% Slope, 0.5m width on left and right) (Point codes = P2 for all 4, And link codes for Top, Datum for all 4). Now when I create the corridor everything looks fine, but the problem comes in when I want to get a Volume of cut and export the corridor to a surface then it appears as though the daylight is wrong for the ditch while the original corridore was fine. I tried adding Daylight corridors to my subassebly I didn't get the desired result. I edited the corridore properties, parameters, surfaces and boundaries with no luck. I suspected I had a problem with corridore boundaries because it would not let me add outer boundaries automatically.
By the way I'm using Civil 3D 2006 SP1 installed.
Could the problem be with my subassemblies, am I choosing the correct subasseblies for a simple ditch? Or do I have to create feature lines of the corridor daylight? Or could it be a corridor boundary problem?
I've watched webcasts and searched this site and tried the help menu with no luck does anyone have any suggestions? Thanks in advance.
Canon
