C3D 2012 Sp4
Win7 Pro
I have an oval roundabout. I created an alignment in the travelway. The alignment does not close on itself, but comes within 0.00001m of the beginning station. I created the Fg profile. I created the corridor surface. I get zero elevation contours in the gap created by the alignment, eventhough the start and end elevation of the FG profile are the same. How do I "Fill In" this gap in the corridor surface.
Solved by wfberry. Go to Solution.
You said the end of the profile comes within 0.00001m of the beginning station. So is that the gap you're talking about? That's so minute that it won't make a bit of difference. I can't imagine how anyone could see that on a normal plan (unless of course you TELL THEM it's there -- and even then, I doubt it).
Don Ireland
Engineering Design Technician
Try changing your corridor ending station slightly less than your alignment.
Bill
@wfberry wrote:Try changing your corridor ending station slightly less than your alignment.
Bill
Oh -- I get it. He means that it's spiking to zero in that gap. I thought he was saying that he wasn't getting any contours there. My duh!
Don Ireland
