No, you don't need to go to LDT. If there's only 1 contour that will be
displayed, then set the Majors at 1.00, with the minors at 0.20, and turn
off the minor display.
wrote in message
news:6241038@discussion.autodesk.com...
> That sux. Oh well, thanks for the info. These are small flat surfaces.
> At least I am not going crazy. Does the same thing happen with 2010? I
> don't normally use 2010 'cause the whole office hasn't upgraded yet.
> Regardless, if I can't get contours to show up on these individual
> corridor surfaces, can I paste them all into one big surface and pull the
> contours from there? If not, then I guess I need to export the surfaces
> in a .xml file to LandDesktop and create contours with that software.
> Ken
