I’m working with superelevations and need some assistance and\or direction to some good learning materials. I don't have an issue creating standard superelevations using "normal" roadway sections (pavement on either side of assembly), but I cant seem to get this specific section to model properly (see attached).
We have a new road project and we have typical section with a median on a curve that we need to apply a superelevation of 3.2% to each side. See attached for the typical section (when not in super). The alignment will be at the center of median and the design speed is 45 mph and I would like some advice on how to properly create the assembly and model within the corridor.
Lastly, If the BEST solution is to use vertical targets, that would be fine too.
Thanks in advance!
Thanks Lisa. I found a good resource: http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2011/autocad-civil-3d/advanced-supe...
