Civil 3D Forum
Corridor Section View Editor
4 REPLIES 4
ccookusi
501 Views, 4 Replies
I have successfully used "Delete a Subassembly" when modifying a corridor section, but have never been able get "Add a Subassembly" to work.
I always get "Unable to Add a Subassembly" at the command line.
What is the proper procedure for this feature?
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
NVMe Samsung SSD 960 Boot
16 GB Ram
4 REPLIES 4
klugb
in reply to: ccookusi
The subassembly you want to attach has to already be inserted into the drawing as a floating or detached sub. Insert one then try to add it in the editor.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
ccookusi
I do have a detached or floating subassembly in the drawing...
I have never been able to get it to work. Same error every time.
Did it work for you in 2011?
Does it work for you in 2012?
Civil 3D 2011 Update 2
Windows 10 Pro x64
Civil 3D 2018
Dell Precision 7720
i7 7700HQ
NVIDIA Quadro P3000
16 GB Ram
klugb
I haven't used the feature but remembered someone mentioning it at AU.
When I tried it I don't get the error message but the results were less than stellar. In one file it acts like it's doing it but nothing shows up and on another one it inserts the subassembly but not at the point I tried to specify and it connected other sub's to this one leaving a mess.
Bruce Klug, P.E.
Civil 3D 2023.2.1
billstreets5403
I have had the same issue...Howver now im having another issue...C3D 2011....Corridor view/edit section i get a "whacked" out view of my cross section...It starts to view properly then goes whacked!! any ideas? thanks
Rail Community
