When creating a Corridor Section Points Report using the Toolspace>Toolbox>Reports Manager in Civil 3D 2012, the stations get listed but only a few contain point information (see attached). I am trying to generate stake-out data for a proposed road. I was able to get this report to work successfully in one of the Civil 3D tutorials, so I assume that nothing is wrong with the utility. The problem may be related to my corridor. Any help would be much appreciated.
I have a simmilar problem did you find a solution for this?
It Happens to me with my Sections. So a Solution I found was.
-Make the report into a Excel file and filter all the CHAINAGE Stations in a way that you can copy/paste only CHAINAGE Stations.
-Clean all CHAINAGE word (With replace into Excel)
-Clean all Plus Mark (You will have Numerical Stations only).
again into C3D,
-In the corridor properties>Parameters Tab> click on (...)Frecuency Button.
-A Frecuency to Apply Assemblies Window will appear, Click on the (+) button and you will be able to add stations.
-In the command bar paste the Numerical Stations you fixed.
-Rebuil the corridor and do the Report Again...
-Your Samples will be there.
Nevertheless. It Work well with most my alignements, but when I have Station Equation , even if the station appear in the model, it doesn't show in the report.
mtf20,
You'll need to create the stake-out points before you can make a report of same.
Here's where I'd start:
Dave
Dave Stoll
Las Vegas, Nevada
yes the corridor beginning station is the point ... if you applied the frequency interval 5 the corridor considers every 5m interval from the beginning station which would lacking the information for the corridor section view report where as the corridor section report considers at every 5m distance but not from the beginning station value !
please go to corridor properties & in parameters change the frequency (lesser) & try to generate the report.
