Can anyone please help me figure out how label only the top of my road surface in section view? The road slopes -2% towards a ditch but my my code set labels both the top of road(-2%) and what I assume is the bottom of the road surface (2%) which I don't want to show.
Is it also possible to label my side slopes as 4:1 instead of 25%? Sorry if this should be a separate thread, I'm just having some trouble wrapping my head around the code set styles.
Any help would be appreciated, thanks
For the duplicate 2%'s...it looks like your code set style is set to label things other than Top or Pave (assuming this is a BasicLane which it appears to be). Change the code ste style accordingly.
Tthe steep slopes can be labeled differently than flat slopes by using expressions to control text height and multiple text components in the label style whose height is controlled by the expressions.
Thanks Jeff and Lisa, you've both been a great help. I still haven't quite figured it out though.
Now in the code set styles (under Link) when I set the "Top" link to Style: Pave ; Label Styl: Flat grade, it labels both my road surface and my side slopes. Then I set the Daylight Links to Daylight Styles and change the label style to "Steep Grades" and it labels my side slopes just the way I want them.
Basicly I just need my code set styles to stop grouping my sideslopes with the road surface, if that makes any sense.
Add a marked point, and a link to marked point to your assembly. Give the link a unique code name (I use "GradeLabel"). Make sure in the assembly properties that the marked point occurs before the link to marked point. Then in your code set, apply the grade label to the link code that you used.
