Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Corridor Section Editor
3 REPLIES 3
cneely
265 Views, 3 Replies
I have a corridor that has had the sections edited individually. Is there a way to globally restore the default parameters for all sections or do I need to do it individually?
AEC Collection 2022
WIN 10 PRO
Dell 3650, Intel i9-11900k @ 3.50GHz, 64 GB
NVIDIA QUADRO RTX 4000
http://www.cobbfendley.com
3 REPLIES 3
tcorey
in reply to: cneely
Go back to the starting section, turn off Overrides at the Baseline level (the very top of the hierarchy.) Go to the ribbon and find Apply to a range of stations. Set the range of stations for which you want to turn off overrides.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sboon
in reply to: tcorey
Alternate method.
Open the parameters tab of the corridor properties dialog.  On the far right side is the Override stations list.  Open that up and use the Delete All button.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
tcorey
in reply to: sboon
There's more than one way to remove the cutis from a feline.
Tim Corey
Redding, CA
Rail Community
Ā
Ā
