I don't manually edit cross sections so now that I need to I'm running into issues. I have an assembly that is 36' street with superelevationaor subassembly where there are driveways and then a 4' sidewalk that is required to be 1% cross slope. I tried using the section editor to manually change the slope of the driveway to tie to existing ground and that works. However the sidewalk subassembly doesnt move to match new driveway. What do I need to do to get the walk to move dynamically with the driveway? Thanks,
Adjust your driveway, extract the feature line from the driveway where the back of walk would tie in.
Which Sidewalk subassembly are you using?
If you use UrbanSidewalk, you can select the previously extracted feature line as horizontal and vertical transition linework. See the Targets button for your corridor region (Corridor Properties, Parameters tab.)
