Active Member
amesteve
Message 1 of 5 (174 Views)
Corridor section editor
174 Views, 4 Replies
02-21-2014 07:20 AM
While working in corridor section editor, I made some changes to the drawing prior to exiting the section editor, Now I can work normally in the tabs (paper space and model space) but when I change to model view, I see almost nothing. I ran the audit and it found no errors, closed and ran recover and nothing was done, saved and reopened and recieved, Drawing cannot locate the project (1113-134 Tallassee Downtown Revitalization-2EE9AA26-CF63-4428-B4F5-BD890B4D8071). What is this and is there any way to restore the connection???
That is Civil 3D telling you it can't reconcile the project association. Go to the Prospector tab of Toolspace, find Data Shortcuts, right click and pick Set Data Shortcuts Project Folder and go pick the project again.
tcorey
Message 2 of 5 (152 Views)
Re: Corridor section editor
02-21-2014 09:33 AM in reply to: amesteve
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
LisaPohlmeyer
Message 3 of 5 (151 Views)
This is the project assigned to the drawing and the message is telling you that it can't locate the project folder. From the prospector tab of the toolspace, in the Data Shortcuts section, rt-click Data Shortcuts and select the working folder. Dang it Tim, you beat me to it.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
tcorey
Message 4 of 5 (145 Views)
02-21-2014 09:35 AM in reply to: LisaPohlmeyer
Always one step ahead...
Tim Corey, Owner
Redding, CA
Active Member
amesteve
Message 5 of 5 (114 Views)
02-24-2014 06:42 AM in reply to: tcorey
This worked on 6 of 7 drawings in the project folder, all but the one that I was working on at the time it happened. Thanks tc and one step behind Lisa for your help.
