While working in corridor section editor, I made some changes to the drawing prior to exiting the section editor, Now I can work normally in the tabs (paper space and model space) but when I change to model view, I see almost nothing. I ran the audit and it found no errors, closed and ran recover and nothing was done, saved and reopened and recieved, Drawing cannot locate the project (1113-134 Tallassee Downtown Revitalization-2EE9AA26-CF63-4428-B4F5-BD890B4D8071). What is this and is there any way to restore the connection???
Solved by tcorey. Go to Solution.
That is Civil 3D telling you it can't reconcile the project association. Go to the Prospector tab of Toolspace, find Data Shortcuts, right click and pick Set Data Shortcuts Project Folder and go pick the project again.
Always one step ahead...
