I'm having a random issue with the daylight tieslopes not tieing to the EG surface at all stations in the Corridor Section Editor. Some stations daylight fine. In planview the daylight lines vary left & right as expected but
don't display at all in Section Editor.
Attached are 2 captions of the issue I'm having which each have a cut & fill occurrence as well as a caption
of the entire align. & corridor.
Any help or ideas is appreciated, I did try deleting corridor & recreating and even recreated a simpler assembly
and still have the daylight issue in same areas of corridor.
Solved by klugb. Go to Solution.
Looks correct from the info posted. Can you email or post the drawing to look at?
If so, remember to promote the EG surface first.
bruce (dot) klug (at) clark.wa.gov
Bruce informed me that there is a known issue in Civil 3D where the Section editor will not display the daylight lines correctly if you have an alignment that doubles back. (My alignment goes from POB south, then west & back to North) in a close proximity. AutoDesk is aware of this issue. Only way to currently get it to display in the Section Editor is to create a surface of the "Top Links".
