What could be the trick with corridor section editor in C3D 2014, applying overrides to a stations range won't work. After selecting or typing end station in the 'apply to a station range' prompt nothing happens, the overrides just will not be applyied.
To apply overrides for an subassembly (curb depth etc) I must go through all the stations set by corridor frequency in the station range. This is not file specific, as it is the case with all my projects.
Ok, I see now in 2014 it applyies changes only backwards. You have to set the override to end station and then set the start station in 'apply to a station range'.
