Active Member
riaangroen
Message 1 of 8 (2,628 Views)
Corridor - Right angle corner / Bowtie
2628 Views, 7 Replies
10-12-2012 01:13 AM
Hi
I have a Corridor issue - does anyone know how to fix the inside / outside corners of right angle corridor?
Im doing a embankment lift and the client wants the corners neatly and not curved or champers.
We often get a problem like, so help would be very nice! Also the outside corner should not curve. I can do it with gradings or futurelines, but if there is a design change i have to redo everything.
See the assembly - this is only the first lift.
Riaan
*Pro
dgordon
Message 2 of 8 (2,564 Views)
Re: Corridor - Right angle corner / Bowtie
10-12-2012 01:35 PM in reply to: riaangroen
feature lines is the best way to do it atm, sorry it's not more dynamic.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
sboon
Message 3 of 8 (2,525 Views)
10-13-2012 09:51 AM in reply to: riaangroen
Assuming that your alignment is at the inside of the berm the solution here is to add a very small radius curve at the corner, then add a single corridor section at the midpoint of that curve.  You will have to use the corridor section view/editor to adjust the assembly parameters for this new section.
Joe-Bouza
Message 4 of 8 (2,504 Views)
10-13-2012 02:34 PM in reply to: riaangroen
riaangroen wrote:
Hi
Riaan
So what kind of corner do you want?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Distinguished Mentor
andrewpuller3811
Message 5 of 8 (2,485 Views)
10-14-2012 01:18 AM in reply to: riaangroen
I think Riann wants the corners to be sharp corners with no chamfers or roundings.
As steve said, a very small arc with a frequency station at the centre.
Here is a step by step post
http://andrewscivil3dstuff.blogspot.com.au/2011/06/create-corridor-with-90-degree-bend.html
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Active Member
riaangroen
Message 6 of 8 (2,452 Views)
10-14-2012 06:50 PM in reply to: andrewpuller3811
hi Andrew
thanks for the blog - iv tried that before but does not quite work. It works well when the surface is close to the ground, but the higher you go, the more complicated it gets.
Iv attached two more pics, second try at the corridor.
The client wants a sharp outside / inside corner. I've tried the small radius, but as the lifts / raises progress, the bigger the arc gets on the outside.
The alignment starts fro the inside going outwards, I've also tried going from the outside going in, but then I end up with a bowtie effect.
This would be easier with offset polylines or gradings but there must be solution for this issue.
I still need to go up 10 lifts / raise, so the arc is going to be massive at the end.
Riaan
Civil 3D
Intel(R) Xeon(R) CPU
X5675 @3.07GHz
64-bit
24GB RAM
andrewpuller3811
Message 7 of 8 (2,445 Views)
10-14-2012 07:40 PM in reply to: riaangroen
You will need to have an alignment to target for the outside that does not have an arc in it.
Offset your base alignment outward using the standard autocad offset command and then fillet the corner/s of the polyline with zero radius to remove the arcs. Create an alignment from polyline and use that as your outside target.
Andrew Puller
Civil 3d 2013 64bit
Neilw
Message 8 of 8 (2,427 Views)
10-15-2012 12:23 AM in reply to: riaangroen
You have encounted a fundamental weakness in Civil 3D: it cannot dynamically model projected mitered corners. You can't do it with with corridors, offset alignments or gradings. The best you can do is minimize the fillet or chamfer by getting as close as you can to the final solution with featurelines or alignments and using them as corridor targets or for gradings.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
