Hi ))
I have 4 Corridors! Every Corridor is devided in parts( regions). Now I want collect all alignments and regions in one place.
Do you know EASY WAY to do it???? for example COPY
Does each region use the same assembly? If so, you can just delete 3 of the regions and make the remaining region cover the station range of all 4 of the original regions.
If you use different assemblies for each region then I don't think you can combine them.
If Conditional Horizontal Targets are used, then various Assemblies can be applied using just a single Region.
But in this case they can't simply be combined if the assemblies are different.
