I have been recently upgraded to C3D 2014 from 2012 and now when I open my old drawings and rebuild my corridor I have an error with the surfaces created (top and datum). Since using 2014, at random locations throughout my corridor sections a double line shows up at random elevations which throw off my compute materials quantities. I have attached a sample of what is happening in case someone else has experienced this issue and can help. I have installed all available hotfixes and SP2.
Have you tried recreating the Materials List and recreating Section VIews to see if that makes any difference?
What does the corridor rebuild error message say?
Can you post the file?
Hi Jay
I have tried Cut and Fill, Earthworks as well as creating my own criteria. In 2012 everything worked fine, I was using the compute materials and mass haul components to try and balance my gradeline but now that I open the file in 2014 I now experience this problem. I tried uploading the file but it is extremely large and seems to fail every time I try. I have even gone so far as to start my file from scratch in 2014 but still end up with the same end result. The thing about it is that this line when it appears ends up being the second corridor surface that I create ( either top or datum). I will try and take a snippit from my drawing and try and post it for you if that will work?
I appreciate you looking at this for me.
Cheers Andre
some subassemblies generated in C3D 2012 don't work well in C3D 2014. i guess this causes the issue. try to create new assemblies in C3D 2014.
I tried creating a completely new assembly in 2014 as well as using the basic road assembly in the tool palette and in both cases the same issue occurs only at different stations along the alignment so this issue does not appear to be related to a specific area of the corridor. I've attached another picture to show what is happening
i guess some surfaces may not been updated accuratly or the data links are broken. remove all the sampled sources from sample line group and see if there are still some sections in the section views.
remove the final sruface from the corridor and create a new final surface may solve the problem.
ZLQ0000
Thanks for the suggestion. I removed all sampled sources and nothing remained in my cross sections but reappeared once again once a sampled the sources. I thought it may have something to do with using shortcuts so I actually created another drawing with all objects within a single drawing, surface horiz & vert alignments , etc and tried the compute materials and created sections but it is still happening.
@Granvillea wrote:
Hi Jay
Cheers Andre
Yes. There is a limit on the size of attachments.
However, if anyone is going to have even a decent chance of helping you on this one, I think you're going to have to provide a data sample. Here are some things to try which should generate a file small enough to upload -- and even if it doesn't get it small enough to upload here, you can always upload it to a dropbox account and share a link with us. The smaller file will make it easier for us to download.
Before doing ANY of this, make sure you save your file and then copy it to a completely differnt location -- then modify the copy.
Don Ireland
Engineering Design Technician
Hello Everyone
First off I want to thank everyone who offered their assistance to my issue. I cannot say how it occurred but for some reason under the build option for the datum and top surfaces from the corridor the exclude elevations option was active which threw off my surfaces. What I found curious was that my OG surface did not have this enabled so I'm a little lost on that one. Again I want to thank everyone for their help.
Andre
