As you can see above, where the red circle is the curb, sidewalk, and daylight just refuse to connect between four of the corridor sections. All four of these sections are in the same region. The problem seems to be that C3D refuses to recognize the offset assembly once it's alignment begins a curve, marked in the image at station 19+75.73. Luckily I don't have to make a cross section at this station, but it's bothersome that the offset assembly inside a region just stops working. The region after this one also has an offset assembly and has no issue.
What's going on? Why does the offset assembly just stop working when the alignment the offset is based on is a tangent then a curve? This is in 2014, btw.
Does this fix it self if you start the region very slightly (.1 units) on the tangent vs the begining of curve?
John Mayo
@jmayo wrote:Does this fix it self if you start the region very slightly (.1 units) on the tangent vs the begining of curve?
The region does not start on the curve. It starts 40.73' before the curve. That's what so strange about this. I did try beginning the region 0.01' after the previous region and it still results in the offset assembly not working at the curve.
What's the curve frequency?
@fcernst wrote:The problem seems to be that C3D refuses to recognize the offset assembly once it's alignment begins a curve
Curve frequency is set to 10'. There are three corridor sections that the offset assembly doesn't show up on. The curve starts at 19+75.73, the next three sections are 19+84.31, 19+85, and the end of the region at 19+86.74. For this region, the length of the curve is 11.01'.
Lower the tangent frequency to one 1' and see what happens.
Can you offer the drawing for inspection?
2015 has more corridor Offset controls:
@fcernst wrote:Can you offer the drawing for inspection?
I can't upload it. However, Autodesk started a SR for this and I've given them the drawing(s). He was able to reproduce it, but it seems that either the corridor region is corrupt, the assembly for that region is corrupt, or the entire corridor is corrupt. Tomorrow when I get more time I'm going to try recreating the region. If that doesn't work, I'm going to recreate the assembly. If that doesn't work, I'm going to create a new corridor that's just in that region and see what happens. If none of those work, then the drawing itself is most likely corrupted.
I'm not going to let C3D 2015 touch this drawing or project. I've already had enough issues with 2015 corrupting survey databases, alignments with profiles, and other issues. This project is currently being constructed and I can't afford to screw this one up.
I would actually delete the Corridor first and try a new one as Step 1 in debugging.
Make sure Regions aren't overlapping also. Here's what happens in 2015 when I overlap regions:
@fcernst wrote:I would actually delete the Corridor first and try a new one as Step 1 in debugging.
I know my region doesn't overlap any of the adjoining regions because I left a small gap between them. I didn't even think you could have overlapping regions as I usually get an error if it's tried.
As for deleting the corridor and redoing it, this is a very large corridor. It's got 8 baselines and 34 regions that'd take me more than a day to redo the frequencies, the targets and the regions as well as the manual superelevations for the last 250+ feet. If this was a newer project that wasn't currently under construction I'd probably do that as a last resort.
Overlapping regions won't crash the drawing. I demonstrated how they can make the Offset assembly subassembly suddenly disappear.
@fcernst wrote:Overlapping regions won't crash the drawing. I demonstrated how they can make the Offset assembly subassembly suddenly disappear.
Not a fatal error, a dialog box stating that it can't be done. However, when I tried doing it in 2014 I don't get the error, but the next region automatically adjusts its station. This didn't used to happen. But even when I make the adjacent regions 1' away from this problem one, the issue still happens.
