Valued Contributor
2 Kudos
Post 11 of 17
Re: Corridor Modeling Question
09-01-2011 10:24 AM in reply to: peterfunkautodesk
yes
David Dixon
Senior Civil Designer
Google+
Employee
88 Kudos
Post 12 of 17
09-01-2011 10:54 AM in reply to: david.dixon
Dave,
I just tried it again in 2012 and it worked fine (once I actually hit the "Add" button to target the elevation).
Peter Funk
Peter Funk
Valued Contributor
2 Kudos
Post 13 of 17
09-01-2011 10:56 AM in reply to: peterfunkautodesk
let me try in 2012 then :smileyhappy:
David Dixon
Google+
Valued Contributor
2 Kudos
Post 14 of 17
09-01-2011 11:03 AM in reply to: david.dixon
no go.  The slope changes but the offset remains 3'.  I set "TargetParameter1" to target the bike path profile.  Does "TargetParameter2" under surfaces need to be set to anything?  Also, why is DeltaY set to "10" in the True definition portion? I can send you my drawing file as well if needed. It's around 5 MB.
David Dixon
Google+
Employee
88 Kudos
Post 15 of 17
09-01-2011 11:09 AM in reply to: david.dixon
Send me the file directly... I have a different version of the PKT, but it works exactly the same for me.
Peter Funk
Peter Funk
326 Kudos
Post 16 of 17
09-02-2011 09:37 AM in reply to: david.dixon
ddixon wrote:
< "BasicLaneTransition" >
I try to stay away from sub assemblies with the word "basic" in the name. Most of thos are for demonstration and learning purposes as the help files often state.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
2 Kudos
Post 17 of 17
09-06-2011 09:03 AM in reply to: Joe-Bouza
Thanks again Peter for your assistance.  Creating a custom subassembly using Subassembly Composer was definitely the answer.  You have opened my eyes to a new and very powerful tool!  I owe you one.
Best Regards,
David Dixon
Google+
