JoaoMM wrote:
> Hi!!.
> I would like to know is Autodesk is thinking in develop a true corridor editor (like Land/Civil) that turn possible change the parameters of corridor manually ??
> In past i use land/civil and i this case I have a possibility to change manually the section, for example distances for transition points, superelevation, etc.
you can change your pavement widths in with the region stuff. But as
far as being able to use the 'classic' autocad tools (trim, extend,
copy, stretch, etc) c3d doesn't let you modify your corridor. From what
I can tell, the most efficient way to do a small project is to crank out
the road corridor, export the surface, make it create contours, tweak
them however you want, then recreate another surface from those
contours. Now granted, this doesn't save any time, is less accurate,
and sure feels a lot like land desktop, and perhaps there is a way to
make the corridor do what you want, but usually it is quicker to just
draft the contours, and move on.
numa
