Civil3D2008 SP2
I know this has to have been covered before, but I can't find it.
I am TOTALLY confused as to how the corridor layering system was set up, and
am having nightmares with my otherwise beautiful corridor. I used the NCD
Extended template to start this drawing in case it matters. I also created
subassemblies using All Codes.
It seems that all of the corridor objects are nested some way back to the
layer C-Road-Corr. This is a nightmare! What I would like to do is to create
a corridor, and have the curb lines, ditches, crownlines, and daylights on
their own layer, but still part of the corridor. I DON'T want to create
separate feature lines that are not attached to the corridor. This is
causing major hassle because even though I have given the Feature Lines
their own layer, turning off C-Road-Corr layer to get rid of the corridor
sample lines also turns off the feature lines. I guess this is because each
of the subassembly markers are coded (or nested) to the C-Road-Corr layer.
Which brings me to a couple of questions.
1. WHY? Why do the marker codes for the subassemblies get automatically
assigned to one layer? Did I do something wrong?
2. What is everyone else doing to create a corridor and just have the normal
things you would see on a site plan show up without the sample lines?
I think I must be totally missing the intent of the corridor programming
because it shouldn't be this hard just to turn off the parts of the corridor
I don't want and cruise along. I don't think it should be this Archaic right
out of the box should it?
Thanks for any advice. I have freshly pulled hair if anyone would like some.
lol
Tim
