AutoCAD Civil 3D General Discussion
jhoff
Message 1 of 9 (285 Views)
Corridor issues
285 Views, 8 Replies
09-18-2012 01:34 PM
I have a driveway design with some widening for turn-arounds.  I made assemblies using the basic lane transition and curb, shoulders etc.  I have alignments to control the widening. I had a couple sections where I needed to adjust the slope.  I used the parameter editor and then applied to a station range.  It worked perfectly.  (that was yesterday)  Today, I opened the drawing to finish up and it constantly says it cannot find target for every single section. I tried rebuilding, I tried new assemblies.  If i touch the parameter editor I immediately get that error and then my only solution is to start over again.  Sometimes I just get that error... What is going on?  I've done some similar designs with no problems.  I did migrate surfaces from an old LDD project.  Was this my mistake?  Any suggestions?  I'm using 2012, sp1, windows7.  The following is from the event properties:
20+50.00':  Target object not found TargetHA
Offset: 0.000' Elevation: 6414.340' Corridor: Corridor - (5) Baseline: RNCH1_PRO_DRIVE Alignment: RNCH1_PRO_DRIVE Profile: RNCH1_PRO_DRIVE Assembly: RNCH1 CURB Assembly Baseline: Subassembly Group: Group - (10) Local Subassembly Name: BasicLaneTransition Global Subassembly Name: BasicLaneTransition - (171) Assembly: C:\ProgramData\Autodesk\C3D 2012\enu\C3DStockSubassemblies.dll .Net Class: Subassembly.BasicLaneTransition Source: BasicLaneTransition
 Etc, Etc for every section in the entire corridor
Thanks in advance for any help,
Totally annoyed in Wyoming
*Expert Elite*
sboon
Message 2 of 9 (284 Views)
Re: Corridor issues
09-18-2012 01:40 PM in reply to: jhoff
Can you post the drawing or post it somewhere so we can look at it?
Valued Mentor
owenmull
Message 3 of 9 (271 Views)
Re: Corridor issues
09-18-2012 02:28 PM in reply to: jhoff
It could have something do with your assemblies.
One thing to look into is making profiles along the widening, and then in your corridor parameters you can tell it to target your widening profiles. I do it this way to make sure C3D holds to the correct slope I want, if I'm doing widening as you are.
Post the drawing, and maybe we can help.
P.S. - Where in Wyoming are you? Who do you work for? I too live and work in Wyoming.
-Owen
Windows 7 x 64 bit
NVidia Quadro K3000M Dual Monitor
32.0 GB RAM
Intel Core i7-3820QM @ 2.70 GHz
Civil 3D 2013 SP 2
______________________________________________________________
Usually, I find that the problem is between the keyboard and the chair.
jhoff
Message 4 of 9 (269 Views)
Re: Corridor issues
09-18-2012 02:34 PM in reply to: jhoff
Can't get it small enough to post.  Thanks though.
*Expert Elite*
sboon
Message 5 of 9 (267 Views)
Re: Corridor issues
09-18-2012 02:35 PM in reply to: jhoff
Dropbox is a good solution also.
jhoff
Message 6 of 9 (257 Views)
Re: Corridor issues
09-18-2012 04:02 PM in reply to: jhoff
Maybe I"ll try drop box tomorrow.  Could my 'BasicLaneTransition' sub-assembly have become corrupted?  I just tried opening a tutorial drawing and built a quick transition section  and immediately had the same error without even touching parameter editor.  Any suggestions? In Jackson, Wy.  Of course autodesk says update to sp2.1...
*Expert Elite*
sboon
Message 7 of 9 (255 Views)
Re: Corridor issues
09-18-2012 04:03 PM in reply to: jhoff
NO !!
Stay away from SP 2.1  Search for my other posts on that one.
Valued Mentor
owenmull
Message 8 of 9 (253 Views)
Re: Corridor issues
09-18-2012 04:06 PM in reply to: jhoff
jhoff wrote:
........................Of course autodesk says update to sp2.1...
NO NO NO NO NO NO NO NO NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Do NOT upgrade to 2.1. Do not listen to Autodesk. The fix is worse than the bug.
If you've already done it, uninstall and re-install to pre-2.1.
Jackson, WY, eh? May as well be California.
-Owen
Windows 7 x 64 bit
32.0 GB RAM
Civil 3D 2013 SP 2
machadt
Message 9 of 9 (211 Views)
Re: Corridor issues
09-20-2012 05:02 PM in reply to: jhoff
I will send you an email with an ftp site login information, please send me your drawing and I will test it with SP2.1 for you.
Could you please send it alone with some step to reproduce?
It is my pleasure to help you.
Tatiana Machado
AEC-ENI Application Engineer
Announcements
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
Need installation help?
