I have a corridor that is following my alignment but crosses a curve and follows the tangent. Why is it doing this and any solutions? This is the first time I have ran into this. Thanks in advance. Attached is a photo of the boundary crossing the curve.
Hard to tell from the image. Do you have an assembly change at that poit? Check all your targets
I think a look at the drawing is needed. Can you post it?
Joe Bouza
I decided to start over with my alignment. I created the alignment from an object then added a default radius for curves and that worked well enough. Thanks everyone for acknowledging my issue. I was unable to figure out why the corridor was ignoring my curve, but figure that it had to do with me adding the curve after creating the alignment... Something was missing, a target perhaps... Thanks again.
Make sure your alignment actually has PIs where you want them. I had the same thing happen and my PIs disappeared for some reason. I think I was because I was able to force a curve and the Alignment got confused.
Only 7 years late!!
