Active Contributor
NeilSpoon
Message 1 of 5 (394 Views)
Corridor Hatch - Non-Solid hatch not lining up between regions
394 Views, 4 Replies
05-17-2012 05:13 AM
I am working on some car parks and am using corridors. There are some area's that consist of seperate regions to tie up corner areas and junctions etc.
I am using link codes to create hatch and would like to use non-solid hatch. But the hatch does not appear to line up properly between regions, as shown on the attached image.
Are there any solutions for this or do I just have to live with it?
Thanks.
Intel Xeon E31230 - 3.20 GHz
4.00 GB RAM
Windows 7 Professional - 64-bit
Nvidia Quadro 600 - 1GB DDR3
wfberry
Message 2 of 5 (387 Views)
Re: Corridor Hatch - Non-Solid hatch not lining up between regions
05-17-2012 05:49 AM in reply to: NeilSpoon
One continuous polyline will solve that.
Bill
Active Contributor
NeilSpoon
Message 3 of 5 (384 Views)
05-17-2012 05:52 AM in reply to: wfberry
How do you mean? This hatch is a result from link codes of the corridor? There are no polylines involved?
4.00 GB RAM
wfberry
Message 4 of 5 (380 Views)
05-17-2012 06:04 AM in reply to: NeilSpoon
Select the hatching areas that are to be continuous then try the AECLINEWORKSHRINKWRAP command, a continuous polyline surrounding this area should be produced on the CURRENT layer.
Re- Hatch.
Bill
Active Contributor
NeilSpoon
Message 5 of 5 (376 Views)
05-17-2012 06:13 AM in reply to: wfberry
Thanks for the suggestion. It does seem to work with regards to making a closed boundary, but it appears to simply enclose the entire corridor and not the areas I want specifically. (ie it includes islands, areas that require different paving construciton etc).
I would prefer if there is a way to simply let the corridor do the hatcing as per link codes and leave it at that. So its completely dynamic.
4.00 GB RAM
