On my corridor I am using Link Slope to Surface, using a 3:1 slope. But it is giving me a 3:1 slope radial to the corridor - what I really need is a 3:1 slope between the contours themselves. On the inside of a tight curve, this makes a big difference. See the attached screenshot. Is there a workaround for this?
No, Corridors layout Links in projections perpendicular to a Baseline.
You'll have to adjust your Daylight grade or your longitudinal Baseline grade... or a combination of both.
Joe Bouza
So basically... do it manually.
I had extracted a feature line at the edge of the road and tried using a Grading to get my 3:1 slope but had the same problem. I was hoping that Gradings would look at the slope between contours instead of radial to the curve, but no such luck. I'm a little surprised that Autodesk hasn't addressed this issue, as I doubt any of us has ever done a job without curves...
Ed
Joe Bouza
You could also extract the edge of pavement feature line from the corridor (tell it to maintain the dynamic link) and then create a grading object based on this feature line that slope to the EG surface at 3:1.
Don Ireland
Engineering Design Technician
@doni49 wrote:You could also extract the edge of pavement feature line from the corridor (tell it to maintain the dynamic link) and then create a grading object based on this feature line that slope to the EG surface at 3:1.
That's what I tried earlier, but it also grades radially to the feature line, instead of maintaining a 3:1 slope between the contours.
I'll have to do it the way Joe suggested above.
Thanks for all of the input.
Ed
HMMMM. that won't work as I expected.
Don Ireland
Joe Bouza
