Civil 3D Forum
Corridor Gap
4 REPLIES 4
nikoue
456 Views, 4 Replies
Corridor Gap
Can anyone explein to me why gaps created where the regions of intersections joins? The daylight feature line stop connecting . See the attached picture. How i can resolve it?
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
4 REPLIES 4
sboon
in reply to: nikoue
You should be able to grip edit the corridor region boundaries to extend them so that they touch.
Steve
Expert Elite Alumnus
nikoue
in reply to: sboon
They seem to touch. I must overlap the regions to connect them. And if i done that the intersection and corridor needs to update. When i update the gaps came back.
Lisa_Pohlmeyer
in reply to: nikoue
Although I like the intersection tool for adjusting profiles, I don't like how it creates the return alignments, we get gaps as well. Our work around to this is to modify the return alignments to have 10' tangent sections on each end.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
nikoue
in reply to: Lisa_Pohlmeyer
The gaps usually appears between the curb return and the full section region. How it will help to modify the return alignment in the end?  The problem is not appear in the end. Also i want to ask you if you modify only the return alignments or you modify the offset alignments too? After your modifications you rebuild the corridor or you update regions and rebuild corridor? If you done the second the modifications still remaining?
Thank you
Rail Community
