Is there a way to use my corridor as a hide boundary on the excisting or finish ground surface. I wand to have a more realistick 3d model in witch the corridor will always visibleand the fg surface will not cover it
Thank you.
I have already done this, but i want to do another.
I want to make a hide boundary because i want to see only the corridor and no the corridor surface.
Create a corridor surface and extract the boundary - then use this
neilyj (No connection with Autodesk other than using the products in the real world)
Thanks for the solution.
But i want to know if i can make it to be dynamic if i make changes to the corridor
The surface boundary will certainly update if the corridor changes but - and I'm not entirely sure about this - you may need to remove the original hide boundary from the definition and then redefine the hide boundary. I don't have any corridors/surfaces immediately to hand otherwise I'd try it myself....!!!!!
if you extract the boundary then its a 3d polyline it cant be update
Yes - you delete the original 3d polyline that you extracted, extract the new corridor surface boundary and use that as the hide boundary
There is no dynamic method for what you are wanting to do as far as I know. But the way it is is very fast.
