How do I make my corridor feature lines to change color? I want daylight cut to be red and daylight fill to be green.I've checked under "Toolspace/Settings/General/Multipurpose styles/Feature line styles/Corridor daylight line - Cut" but it doesn't work.
Thanks for your help.
Solved by jmayo-EE. Go to Solution.
The feature line style you want to assign is in the code set. You will need to edit the code set being used by that corridor.
John Mayo
Click the Import Codes button. This will populate the code set with all of the codes in your corridor. You can then assign the appropriate styles.
John Mayo
