My corridor seems to be targeting a portion of the alignment some 1700 feet upstation (see attachment). Is there a setting to limit this? Or a workaround/solution?
Thanks.
C3D 2014
Solved by BrianHailey. Go to Solution.
Split your region and change the targets for the different regions.
It's tough to tell what's going on without seeing the actual drawing in a case like this.
Or perhaps your alignment isn't at the exact center of your cul-de-sac and the outside corridor baseline can't target the center alignment at that specific location but it can way over at the other side of the project.
Just thinking out loud on this one.
