Civil 3D Forum
Corridor Feature Line Styles
4 REPLIES 4
neilyj666
496 Views, 4 Replies
I have created Road 1 and assigned Feature Line Styles in the Feature Lines tab of the Corridor Properties and it looks as I expected.
When I go to Road 2, 3 etc I have to manually assign the Feature Line Styles again, so the question is can these feature line styles be assigned via a code set or something.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
4 REPLIES 4
wfberry
in reply to: neilyj666
I believe that Toolspace -> Settings -> Grading -> Commands ->  (look at the default styles here.)  should work.
Bill
Jeff_M
The Code Set Style also assigns the Featureline styles. When you create a new corridor, or a new region, C3D assigns the Featurlines per the Code Set Style. However, unlike the points/links/shapes, the Featurelines will not update after creation based on the current Code Set. Once they are created, then they must be edited in the corridor properties.
Jeff_M, also a frequent Swamper
neilyj666
Thanks - that's a bit poor on the part of the programmers, I feel a wish list request coming on.....
fcernst
in reply to: Jeff_M
Still the same in 2013 and a royal pain...Totally runs against the Code Set paradigm that is flaunted as correct C3D workflow...
Autodesk: Can we get this addressed in 2014 or 2013 SP2?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Rail Community
