I have created Road 1 and assigned Feature Line Styles in the Feature Lines tab of the Corridor Properties and it looks as I expected.
When I go to Road 2, 3 etc I have to manually assign the Feature Line Styles again, so the question is can these feature line styles be assigned via a code set or something.
Solved by Jeff_M. Go to Solution.
I believe that Toolspace -> Settings -> Grading -> Commands -> (look at the default styles here.) should work.
Bill
The Code Set Style also assigns the Featureline styles. When you create a new corridor, or a new region, C3D assigns the Featurlines per the Code Set Style. However, unlike the points/links/shapes, the Featurelines will not update after creation based on the current Code Set. Once they are created, then they must be edited in the corridor properties.
Thanks - that's a bit poor on the part of the programmers, I feel a wish list request coming on.....
Still the same in 2013 and a royal pain...Totally runs against the Code Set paradigm that is flaunted as correct C3D workflow...
Autodesk: Can we get this addressed in 2014 or 2013 SP2?
