Civil 3D Forum
Corridor feature line missing
2 REPLIES 2
ebarlevi
295 Views, 2 Replies
I have a corridor with the two daylight points marked as BOUL BOUR.
I have sample lines every 20 meters, and cross sections accordingly.
At each section I deliberately marked the above points, to make sure that exist at each section.
When building the corridor (at frequency of 20 meters only, no other points), I marked the points as feature lines.
For some reason the feature lines are broken in many places.
Any idea why, and solution?
2 REPLIES 2
jmayo-EE
in reply to: ebarlevi
Is there enough surface to compute the full daylight? Try changing it to 1:1 does this fix it?
Double check the baseline profile. If this get's wacky the resulting daylight will also be wacky.
John Mayo
ebarlevi
in reply to: jmayo-EE
Yes there is enough surface.
I am trying something else.
Will let you know if it works.
Rail Community
